RBAero
JMP Distribution Platform not arranging Distributions in Rows
Hi Team
I have done this many times
But all of a sudden today , i am not able to arrange my distributions in rows
See snapshots below
I am using JMP15.2.1
Thanks for help
Re: JMP Distribution Platform not arranging Distributions in Rows
The issue you are running into is that when you use a By() clause, the option to place the output into x number of rows, treats all of the graphs for a given parameter(column) as one element, regardless of the number of graphs produced by the By() clause.
A work around for this, is to create a new window and to use a LineUpBox() to specify the number of graphs per row
// Open Data Table: big class.jmp
// → Data Table( "big class" )
New Window( "Distributions",
	Lineup Box( N Col( 3 ),
		Distribution(
			Arrange in Rows( 3 ),
			Continuous Distribution( Column( :height ) ),
			by( :age )
RBAero
Thanks Mr Nelson
I am not so good with scripting in General
is this an option available in Distribution platform which i can choose
As this is happening now in my multiple datasets
Ranjit
It is not a Distribution Platform option.  It is only available in JSL
RBAero
I think i have an issue with my script too
When i run my distribution By years & save it,
While running it again it only pull 2018 Year data, see snippet & script below.
Distribution(
Column( :Calorific Content ),
Horizontal Layout( 1 ),
Vertical( 0 )
Where( :Years == 2018 )
There are 2 separate selections when you Save Script for Distribution.
  1. Save Script
  2. Save By Group Script
You apparently selected the Save Script, which will output the script for just the Group you selected the red triangle from
You need the Save Script , which outputs with the By clause
Distribution( Continuous Distribution( Column( :height ) ), By( :age ) );
