JMP Calculator
In JMP we can do calculation using the JMP calculator.
The parameters in the formula are the columns table, attached is a simple formula subtracting y column from x column with LAG,
What I want to know is if there is a way to use different lag for different rows.
((Lag( x, 2 ) - :y) / Lag( x, 2 )) * 100
Thank you
Yaakov
XanGregg
Re: JMP Calculator
Yes, replace the "2" in the Lag function with some expression that depends on Row(). For instance,
Lag( x, If( Row() < 10, 2, 3 ))
That uses a lag of 2 for the first 9 rows and 3 for the others.
Re: JMP Calculator
Xan,
WOW, very helpful.
I assume it is possible to put the "If" outside the formula and the "Lag" inside.
Also, I assume it is possible to make it more complex,for example many different lags for many different rows.
Thank you very much.
Sharon
