How to show full column name when it is too long?
I have a table, each of its columns usually is assgned with a prettly long name for easy interpretation.
So after I generate or load it into JMP, each time I have manually adjust each column to make sure
its full name can be shown properly.
But this is too annoying when columns are too many.
So if I can control its display by JSL, any idea I can make this automatic column width adjustment?
Thanks so much.
Fred
dggoldst
Re: How to show full column name when it is too long?
If you select the full columns (not just the header but the full colums so that they turn white) then adjust one of them while holding the ALT key, all will snap to that size. If all the columns are ridiculously wide, make a narrow column just for this purpose then delete it when done.
