kwmcm
JMP 16 and the updates to Journaling
Hi all,
I make Journals as the best way to share my graphs with others that use JMP.
With the new JMP 16 update, it has become tedious. I usually would do "ctrl + J" and the graph that is highlighted would gracefully appear in a new journal.
Now when I do it, I get the picture that is attached and not my gorgeous graph I am trying to share with others.
I haven't been able to figure out A. what is happening... B. how to make it stop.
Any advice is appreciated!
Re: JMP 16 and the updates to Journaling
The Using JMP document in the JMP Documentation Library gives the details on the new Journaling environment.    Here is what I have discerned in the few minutes I played with it.
What is happening, is that when you paste into a new journal, it comes up in an interactive editing environment.
At this point, it is not a completed document, so you can continue adding and moving documents within the journal.  At the top of the window, there is a semi transparent tool bar which when hovered over, displays some editing tools
What I believe you want to do, is to click on the red triangle in the tool bar and select "Lock Journal"
It will give you a finished journal
It is my suggestion that you take the time to read up on the documentation on the journals in the Using JMP document.....just as I will be doing.
Jim, I was writing while you responded. Thanks so much for that. I didn't know that and those new options did not affect my typical use of journaling?....
kwmcm
Hi Jim,
Thanks for your reply- I did read the literature about the updates and am aware of the hovering editing feature. That's not what my problem is, however.  My problem is the graph doesn't go to the journal. It's just an empty box with X's inside, like the picture I added.
Thanks tho!
What operating system are you using?
@kwmcm . Sorry for your troubles.  I've been trying to replicate an issue of journaling on JMP 16 and have not been able to.  In every case when I select ctrl J it properly journals the active window.
Could you perhaps attach a data table where you are seeing the issue? OR submit the "issue" to support@jmp.com.
