Fiona_Baines
JMP 15: get function doesn't work with modal windows
If you try this script (obtained from the scripting index in JMP 15)
New Window( "Example",
	<<modal,
	numbox = Number Edit Box( 0 )
Print( numbox << Get );
and edit the number box you get this error:
deleted object reference: numbox << Get in access or evaluation of 'Glue' , Names Default To Here( 1 ); /*###*/New Window( "Example",
	<<modal,
); /*###*/Print( numbox << Get ) /*###*/;
This used to work in JMP 13, how do you now get values from editable boxes in JMP 15?
Re: JMP 15: get function doesn't work with modal windows
Here is how you need to code your script in JMP 15
	<<modal,
	numbox =
	Number Edit Box(
		0,
		10,
		<<SetFunction(
			Function( {this},
				numbox = this << get
Print( numbox );
David_Burnham
Alternatively, use <<onClose to grab all your results from the window.  You can also use <<onOpen to intialise values and  <<onValidate to validate inputs.
NewWIndow("Example", <<modal,
    <<onClose(
        value = numbox << get;
    numbox = NumberEditBox(0)
-Dave
	<<modal,
	numbox =
	Number Edit Box(
		0,
		10,
		<<SetFunction(
			Function( {this},
Print( numbox );
vince_faller
Could also use the return results.
Names default to here(1);
nw = New Window( "Example",
	<<modal,
	<<Return Result,
//changed the numbox to 1 show(nw); // {numbox = 1, Button(1)}
Vince Faller - Predictum
David_Burnham
    <<onClose(
-Dave
