LBrian
How to use contains() correctly?
Hi, All
I wanna use contains(),
dt = Open( "$Sample_Data/Blood pressure.jmp" );
colNamesList = dt << get column names( continuous );
Input = New Window( "example", << modal(),
	new1 = hlistbox(
	Text Box( "Test name :" ),
	Para_Num_teb = Text Edit Box( "", <<set width( 200 ) )
		text box("Click OK"),
		Button Box( "OK",
		Para_Num = Para_Num_teb << get text();
if (!contains(colNamesList, Para_Num),
	Throw("Fail ")
however,
Fail message occurs everytime on this script which i made.
Could you give me any advice?
Re: How to use contains() correctly?
The issue you are having is that you are retrieving a character string variable from your Button Box, but your list of column names are expressions
para_num = "zippy";
colnameslist = {BP 8M, BP 12M, BP 6M, BP 8W, BP 12W, BP 6W, BP 8F, BP 12F, BP 6F};
If you just specify to have the colNamesList returned as strings, your code will work
colNamesList = dt << get column names( continuous, string );
para_num = "zippy";
LBrian
Thank you very much Doctor!!!
