- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
JMP 15: get function doesn't work with modal windows
If you try this script (obtained from the scripting index in JMP 15)
New Window( "Example",
<<modal,
numbox = Number Edit Box( 0 )
Print( numbox << Get );
and edit the number box you get this error:
deleted object reference: numbox << Get in access or evaluation of 'Glue' , Names Default To Here( 1 ); /*###*/New Window( "Example",
<<modal,
); /*###*/Print( numbox << Get ) /*###*/;
This used to work in JMP 13, how do you now get values from editable boxes in JMP 15?
- Tags:
- JMP 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: JMP 15: get function doesn't work with modal windows
Here is how you need to code your script in JMP 15
<<modal,
numbox =
Number Edit Box(
0,
10,
<<SetFunction(
Function( {this},
numbox = this << get
Print( numbox );
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Created:
Jun 10, 2020 12:10 PM
| Last Modified: Jun 10, 2020 9:12 AM
(2433 views)
| Posted in reply to message from vince_faller 06-10-2020
Alternatively, use <<onClose to grab all your results from the window. You can also use <<onOpen to intialise values and <<onValidate to validate inputs.
NewWIndow("Example", <<modal,
<<onClose(
value = numbox << get;
numbox = NumberEditBox(0)
-Dave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
<<modal,
numbox =
Number Edit Box(
0,
10,
<<SetFunction(
Function( {this},
Print( numbox );
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Created:
Jun 10, 2020 11:31 AM
| Last Modified: Jun 10, 2020 8:32 AM
(2440 views)
| Posted in reply to message from Fiona_Baines 06-10-2020
Could also use the return results.
Names default to here(1);
nw = New Window( "Example",
<<modal,
<<Return Result,
);//changed the numbox to 1
show(nw); // {numbox = 1, Button(1)}
Vince Faller - Predictum
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Created:
(2434 views)
<<onClose(
-Dave
