JMP 14.3 Add ins available
Is there any site with add-ins for older JMP version like V14?
Re: JMP 14.3 Add ins available
Hi @AttributedWalk1,
You might find some older scripts on GitHub for JSL. Depending on what the add-in does, they may work in 14 as all add-ins are essentially JSL scripts - if the functions exist in 14 and haven't changed then they should in theory work.
Thanks,
Ben
