SpannerHead
Iteratively Create Columns Containing All Permutations of Subtraction from an Initial List of Columns
I have a list of columns and I need to create a new series of columns with every permutation of the difference between the listed columns.  The number of the columns in the list can vary and the non-iterative example below covers 3 columns (12 to 14).
Current  Data Table() << New Column(Head Name( As Namespace( Column( 12 ) ) )||" - "||Head Name( As Namespace( Column( 13 ) ) )||" HSD Threshold Matrix", Numeric, "Continuous", Format("Best", 10), Formula(Col Maximum(If(Contains(:Level, Head Name(As Namespace(Column(13))), 1), As Column(12)), :Group, :Size)));
Current  Data Table() << New Column(Head Name( As Namespace( Column( 12 ) ) )||" - "||Head Name( As Namespace( Column( 14 ) ) )||" HSD Threshold Matrix", Numeric, "Continuous", Format("Best", 10), Formula(Col Maximum(If(Contains(:Level, Head Name(As Namespace(Column(14))), 1), As Column(12)), :Group, :Size)));
Current  Data Table() << New Column(Head Name( As Namespace( Column( 13 ) ) )||" - "||Head Name( As Namespace( Column( 14 ) ) )||" HSD Threshold Matrix", Numeric, "Continuous", Format("Best", 10), Formula(Col Maximum(If(Contains(:Level, Head Name(As Namespace(Column(14))), 1), As Column(13)), :Group, :Size)));
Slán
SpannerHead
SpannerHead
Re: Iteratively Create Columns Containing All Permutations of Subtraction from an Initial List of Columns
Not sure if this is what you meant but I found something here that works.  What's even better about this is that it doesn't rely on column numbers.
Names Default to Here(1);
//Select X Variable ____________________________________________________________________________________________________________________________________________
cdb = Column Dialog("Add continuous variables you want to plot as X" ,
	colxx = ColList( "X", Min Col( 1 ) ),
show(cdb);
Eval List(cdb[1::N Items(cdb)-1]);
Summarize(dt, uniqNames = by(colxx[1]));
Show(uniqNames);
Num = NItems(uniqNames);
For( k = 1, k <= N Items( uniqNames )-1, k++,
For( i = k+1, i <= N Items( uniqNames ), i++,
if (i > k, Eval(EvalExpr(Current Data Table() << New Column(Char(uniqNames[k])||" - "||Char(uniqNames[i])||" Matrix", Numeric, "Continuous", Format("Best", 10), Formula(Col Maximum(If(Contains(:Level, Expr(Char(uniqNames[i])), 1), As Column(Expr(Char(uniqNames[k])))), :Group, :Size)));
Solved: Get column values using Loop - JMP User Community
Slán
SpannerHead
dt = Open("$SAMPLE_DATA/Cities.jmp");
mycols = {"OZONE", "CO", "SO2", "NO", "PM10"};
possible_group_idx = NChooseK Matrix(N Items(mycols), 2);
my_groups = Transform Each({idx}, As List(possible_group_idx), Output("List"),
	mycols[idx]
For Each({cols}, my_groups,
	Eval(Substitute(
		Expr(dt << New Column(cols[1] ||"_"||cols[2], Numeric, Continuous,
			Formula(_col1_ + _col2_)
		Expr(_col1_), Name Expr(AsColumn(dt, cols[1])),
		Expr(_col2_), Name Expr(AsColumn(dt, cols[2]))
Write();
You can for example use NChooseK Matrix() to create the combinations (or DoE)
mylist = {12, 13, 14};
possible_group_idx = NChooseK Matrix(3,2);
my_groups = Transform Each({idx}, possible_group_idx,
	mylist[idx]
[12 13, 12 14, 13 14]
SpannerHead
Jarmo
Thanks, looks like it will work.  Haven't had time to study the details but wondering if there's an example of how it can be employed?
Slán
SpannerHead
Loop over the matrix (or turn it into list of lists) and create the columns as you do that.
SpannerHead
show(cdb);
Show(uniqNames);
Slán
SpannerHead
	mycols[idx]
	Eval(Substitute(
Write();
