Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
Jaz
Jaz
Iterating Through two Data Tables of Different Sizes & Comparing for Matching Values
I have the following problem:
- I have two data tables in seperate jmp files, each of which has one column.
- One table is 8 rows long whilst the other is 6440 rows long.
-  My aim is to go through each of the values in the 8-row table and compare them to every value in the 6440-row table to see if they match.
- I was just wondering how I could go about doing this because I want to iterate through both tables but they are different sizes. I was thinking of using a nested for loop but I'm not too sure.
Any help would be appreciated.
Re: Iterating Through two Data Tables of Different Sizes & Comparing for Matching Values
I made a slight error in my previous pseudo code example,
dtShort:Compare Column[i] > dtLong:Compare Column
Needs to be reversed in logic for it to work
 dtLong:Compare Column > dtShort:Compare Column[i]
Here is a working example
dtLong = Open( "$SAMPLE_DATA/Big Class.jmp" );
// Create the short data table
dtShort = New Table( "Short",
	New Column( "Target Age", values( {12, 16} ) ),
	New Column( "Match", character, values( {"Teenager", "Young Adult"} ) )
// Sort the data for illustration of data not being
// in age order
dtLong << sort( by( :Name ), replace table( 1 ) );
// Create a couple of new columns in the data table
dtLong << New Column( "Kind Of Match", character );
dtLong << New Column( "Count" );
// Process the data
For( i = 1, i <= N Rows( dtShort ), i++,
	// Find all rows that match the Where Clause
	theRowsFound = dtLong << get rows where( dtLong:Age > dtShort:Target Age[i] );
	// If some rows were found process
	If( N Rows( theRowsFound ) > 0,
		// Set a value in the dtLong data table with one statement
		// that sets values in multiple rows
		dtLong:Kind Of Match[theRowsFound] = dtShort:Match[i];
		// Now set values row by row for individual rows that were found
		theCount = 1;
		For( k = 1, k <= N Items( theRowsFound ), K++,
			dtLong:Count[theRowsFound[k]] = theCount;
			theCount = theCount + 1;
I believe the easiest way to do this would be to let JMP do the work for you.  If you Join the tables into a new table, you can have JMP create a new column called Match flag, which will tell you if a match was found or not
     Tables==>Join
Jaz
Jaz
Thanks for your reply.
How would you suggest going about the problem if I wanted to check if the value in the 8-row table is greater than the value in the 6440-row table?
Here is how I would process it.......
// This is pseudo code, but it will give you an idea of the flow
dtShort = Open( "<your short data table>" );
dtLong = Open( "<your long data table>" );
	theRowsFound = dtLong << get rows where( dtShort:Compare Column[i] > dtLong:Compare Column );
		// Do your processing
Jaz
Jaz
Thanks for the quick reply.
For the following part:
dtLong : Compare Column
Do you mind explaining how I could access all the values in a column without having to reference to each subscript/index of the column?
// in age order
// Process the data
		theCount = 1;
