Ksrzg01
Iterate Through Data Table to Select Matching Items in Another Data Table
Good Morning All,
I am trying to create a script which will iterate through two columns on one data table and select all of the matching characters on another data table to perform a simple bivariate graph. To help visualize, consider me trying to iterate through Little Class.JMP by Sex and Name and select all matching rows on Big Class.JMP, then for each iteration, graph height by weight.
Re: Iterate Through Data Table to Select Matching Items in Another Data Table
Is this what you are thinking of?
dt = Open( "$SAMPLE_DATA\big class.jmp" );
dt << select where( Mod( Row(), 3 ) == 0 );
dtlookup = dt << subset( selected columns( 0 ), selected rows( 1 ) );
For( i = 1, i <= N Rows( dtlookup ), i++,
	dt << clear row states;
	dt << select where( dtlookup:name[i] == dt:name & dtlookup:sex == dt:sex );
	dt << invert row selection;
	dt << hide and exclude( 1 );
	biv = Bivariate( Y( :height ), X( :weight ) );
	Report( biv )[Outline Box( 1 )] << set title( dtlookup:name[i] );
9 REPLIES 9
Ksrzg01
This is pretty close to what im looking for. Now imagine I have a column of random ages in another table. I want the script to go down the column of the various ages, subset the ages from the big class DT, and plot the hight by weight. I know I could just do a fit x by y by age but the data set I'm looking at is too large to do this.
The code I gave you just needs to be expanded to the logic you described in your response.  You should be able to write that code given the leg up of my example, and access to the Scripting Guide and Scripting Index
     Help==Books==>Scripting Guide
     Help==>Scripting Index
Ksrzg01
Thanks for the help Jim! Finally got it all figured out with very little variation to the solution you provided me.
Ksrzg01
Hey, one last thing. How can I save each individual graph to a journal?
Here is the example from the Scripting Index on saving to a journal
//This message applies to all display box objects
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Journal( "path/to/example.jrn" );
Ksrzg01
Worked great. Thanks!
jj_jmp
Should it be this? I don't see why name gets [i] but sex does not get [i]
dt << select where( dtlookup:name[i] == dt:name & dtlookup:sex[i] == dt:sex );
//rather than
You are correct
