gpuckett
Issue running JSL files in C#.NET
I am trying to execute JSL files in a C#.NET wrapper. I am able to sucessfully run the files but my code does not wait for the script to finish. Below is a sample:
JMP.Application jmpInstance = new JMP.Application();
FileInfo fJSLFile = new FileInfo(@"C:\Test\Test.JSL");
jmpInstance.RunJSLFile(fJSLFile.ToString());
if (jmpInstance.HasRunCommandErrorString())
     throw new ApplicationException("Error with JMP script: " + jmpInstance.GetRunCommandErrorString());
uday_guntupalli
Level VIII
Re: Issue running JSL files in C#.NET
@gpuckett
       Were you able to figure this out ? I am looking to run JSL functions by passsing parameters to it from C#. Wondering if you could share any insight ?
Best
Uday
ChrisM_X
I use myJMP.RunCommand(command); to pass data to JMP for C#, where command is a string you build up in C# to set up variables.
example
JMP.Application myJMP = new JMP.Application();
string command = "a=1";
Example code snippet below:
Below I set spec limits properties on columns that have specs:
foreach (var item in Specs)
bool setprops = false;
StringBuilder SpecList = new StringBuilder();
if (item.Value.LowerSpec.ToLower() != "nan")
SpecList.Append("LSL(Expr(" + item.Value.LowerSpec.ToLower() + ")),");
setprops = true;
if (item.Value.UpperSpec.ToLower() != "nan")
SpecList.Append("USL(Expr(" + item.Value.UpperSpec.ToLower() + ")),");
setprops = true;
// SpecList.Length--; //removes last characther from SB (ending comma)
if (setprops)
command = @"Eval(
Eval Expr(" +
"column(dts, Expr(\"" + item.Key + "\")) << set property(" +
"\"spec limits\"," +
" {" + SpecList.ToString() + " Show Limits( 1 )}" +
uday_guntupalli
Level VIII
@ChrisM_X
  Thank you for the snippet. I am trying to understand, where in your snippet are you invoking a function ?
TestPower = function({base,expn},{default local},
			res = base ^ expn ;
			Retrun(res);
Let us assume we have a user defined function in JMP like the one shown above. Now, starting from C#, how can I invoke this function by passing it parameters for base and exp and run this function ?
The snippet you shared addresses the part about how we can use the RunCommand function to pass a value, but can you use a simple example like this to explain the process a little more in detail ?
So, if i have the above function stored as TestPower.jsl on my C:\ , can you kindly share on how I would be able to run using C#, by passing it the parameters and calling this function ?
Best
Uday
uday_guntupalli
Level VIII
@ChrisM_X,
        I actually managed to get it to run using your suggestion and a little luck of playing around. Here is my C# code that works.
            // Create an instance of JMP and make it visible
            JMP.Application MyJMP;
            MyJMP = new JMP.Application();
            MyJMP.Visible = true;
            MyJMP.ShowStartupWindow();
            MyJMP.EnableInteractiveMode(true);
            // create command
            string arg1 = "base = 2"; // arguments to my User defined function in JSL
            string arg2 = "expn = 3"; // arguments to my User defined function in JSL
            MyJMP.RunCommand(arg1);
            MyJMP.RunCommand(arg2);
            string FilePathOfFileToRun = "C:\\Test.jsl";
            MyJMP.RunJSLFile(FilePathOfFileToRun); // Running the user defined function
            // Needed to keep JMP from automatically closing
            JMP.DataTable dt = MyJMP.NewDataTable("test");
            MyJMP.RunCommand(@"Close(Data Table(""test""), NoSave)");
Best
Uday
