vince_faller
Is there an easy way to script the Fit Model Macros?
I can't believe I've never asked this before, but does anyone know if I can give a script just what macro to run on what I have selected?
Like say I want to do response surface on "Age" and "weight"
Names default to here( 1 );
dt = open("$SAMPLE_DATA\Big Class.jmp");
dt << Clear Column Selection();
dt << Select Columns({"weight", "age"});
fm = dt << Fit Model(Y(:height),
	// do something involving Response Surface
// So that the final report looks the same as.
fm_real = dt << Fit Model(
	Y( :height ),
	Effects( :age, :weight & RS, :age * :weight, :weight * :weight ),
	Emphasis( "Effect Leverage" ),
	Run()
I built a bunch of helper functions to do this previously and I really don't want to have to build them again.
Vince Faller - Predictum
peng_liu
Re: Is there an easy way to script the Fit Model Macros?
Try this:
dialog = dt << Fit Model(
dialog << Y( :height );
dialog << Effects(Response Surface(:weight, :age));
dialog << Run();
peng_liu
I have added its OSI documentation to JMP17. You should be able to find it under OSI > Objects > Fit Model > Model Dialog > Item Messages > Effects.
For FactorialToDegree and also PolynomialToDegree, what you did is not what you think it is. The arguments in side of the Macro names are interpreted as columns. So in your example, the number 2 is interpreted as the second column, which is :age. And FactorialToDegree and PolynomialToDegree will refer to the value in the Degree number edit box as the value for degree.
In JMP 16 and previous versions, you may have to go through display box scripting to change that. E.g.
report(dialog)[NumberEditBox(1)] << set (3);
dialog << Effects(FactorialtoDegree(:height, :weight, :age));
I made small improvement in JMP17. You will see it in the Effects OSI item when you have JMP17.
peng_liu
Try this:
dialog << Run();
vince_faller
Amazing. Is there any documentation on this?  It's not in the scripting guide or index.  Can I do factorial to degree X?
*Edit* I figured it out.  Seems like it's just the exact wording of the macro.
dialog << Effects(FactorialtoDegree(2, :weight, :age));
@ben_ph this might be useful to you too.
peng_liu
StarfruitBob
@peng_liu, are these commands new in JMP 17? I have the exact same question as Vince, but they don't seem to work in JMP 16.
  • Response Surface()
  • FactorialtoDegree()
Learning every day!
peng_liu
These? They are in 17.
