mochar
Is there a way to run a JSL script with an input?
I'm wondering if I can run a jsl remotely and give it a directory right away...
I have a jsl script that uses a directory of a file and executes some commands. I would like to send it the directory of the file in a simple way where gui's wouldn't be involved (hopefully).
this is how i execute a jsl script from my PC at the moment:
os.system('cd "C:/Program Files/SAS/JMP/14/" && jmp.exe "directory_to_script\blah.jsl"')
wondering if sending another line of code would send it the directory? Any clue, or any ideas to how to do this in a clean way?
6 REPLIES 6
Craige_Hales
Re: Is there a way to run a JSL script with an input?
Use an environment variable, and GetEnvironmentVariable("name") in JSL to retrieve it. (You can't use SetEnvironmentVariable(...) to return it, as far as I can tell.) @briancorcoran Environment Variable named RALPHEnvironment Variable named RALPH
JMP gets a copy of the environment when it starts.
Craige
Craige_Hales
A little more complete example:
Environment variable AND a scriptEnvironment variable AND a script
You could also end the script with a quit(); command if needed.
Craige
mochar
Whenever I look at my log window, Get environment variable("RALPH" = "";
in my cmd window, it tells me that 'RALPH' is not recognized as an internal or external command
Craige_Hales
Use the SET command in the CMD window to set environment variablesUse the SET command in the CMD window to set environment variables
Craige
mochar
Thanks! Was able to finally make it work with your help.
Can this be done with more than one environment variable? Can I have 2 or three environment values at a time?
pmroz
Yes you can have as many environment variables as you need.
