thentangler10
Is there a way to pin tool tips on graphs
When i hover over my graph that has labels set, I would like an option to pin the tooltips so that I can annotate multiple areas of the graph with the tooltips.
Is there a way to do this in JMP?
Re: Is there a way to pin tool tips on graphs
I replicated your finding.  If I zoom in, the label becomes visible, but when the field is displaying  all points, the labels are not visible.
12 REPLIES 12
mmarchandTSI
Level V
Do you mean like this?
If you move your mouse over the hover label, a pin icon appears.  Click that to make the label persistent.
thentangler10
Exactly!, But i dont see the pin icon in graph builder.
What should i do to make it visible?
mmarchandTSI
Level V
Just move the pointer over the hover label itself when it appears.
thentangler10
I dont see it
mmarchandTSI
Level V
(view in My Videos)
If you are wanting to statically display the labels for specific points on your graph, you can set the Label state for the specific rows you want to have the static data displayed for.
thentangler10
I want to show a particular point in my line plot. I select 2 rows as you suggested, but I dont see them show up in the graph.
I have set my desired variables to be shown as labels in te variable columns too.
Please note that you need to also add a Label parameter for the columns whose values you want listed..  The image below has both the Label Row State set for the rows to have the displayed values and the Label set for the columns Name and Age.
thentangler10
I did that, But it doesn't seem to work.
My data set has more than 10,000 points, I just marked a couple of rows and their corresponding label parameter in a specific column i wanted to be shown on the graph.
Is it not working because of the number of points?
