thentangler10
Is there a way to pin tool tips on graphs
When i hover over my graph that has labels set, I would like an option to pin the tooltips so that I can annotate multiple areas of the graph with the tooltips.
Is there a way to do this in JMP?
12 REPLIES 12
Re: Is there a way to pin tool tips on graphs
I don't think that amount of data points should cause that kind of an issue
If you want to show some specific points in your data, create new column, fill only those values in, label those rows, add points to your plot and plot points and lines.
I replicated your finding.  If I zoom in, the label becomes visible, but when the field is displaying  all points, the labels are not visible.
thentangler10
Yup! That was the issue!
Thank You!
