agripenwal
Is there a way to limit the number of decimals in the prediction profiler response prediction?
I would like to set the prediction of the prediction profiler to have the same accuracy as the measurements that the prediction is based on, is there a way to do this?
ledi_trutna
Re: Is there a way to limit the number of decimals in the prediction profiler response prediction?
If you set the format of the response column to be fixed decimal with the desired number of decimal places, the format will apply to the predictions in the prediction profiler.
ledi_trutna
agripenwal
Thank you
