Is there a way to limit the number of decimals in the prediction profiler response prediction?
Created:
Jun 18, 2021 07:10 AM
| Last Modified: Jun 11, 2023 4:15 AM(2336 views)
I would like to set the prediction of the prediction profiler to have the same accuracy as the measurements that the prediction is based on, is there a way to do this?
If you set the format of the response column to be fixed decimal with the desired number of decimal places, the format will apply to the predictions in the prediction profiler.
