aimeeh60
Is there a way to insert a comment in a cell?
I have a data point and would like to attach a comment to it in the cell, similar to inserting a comment in a cell in an Excel spreadsheet.  Is this possible?
stan_koprowski
Re: Is there a way to insert a comment in a cell?
Hi @acitretin,
What @ron_horne suggested is to use the label/unlabel option for the column to display values.
With it on you can display additional details as seen in the attached.Label/Unlabel to display values or commentsLabel/Unlabel to display values or comments
cheers,
Stan
Craige_Hales
You can add a color to a cell, or add a comment column:
You can also add a comment for an entire column and for an entire data table via the columnProperties->other or the data table's NewTableVariable.
Craige
ron_horne
In addition, one can use the comments column as a label for graphs. In which case it is possible to label just that row or as many rows you want.
ron
aimeeh60
Thanks for the replies.  Good to know.
A~
acitretin
Dear Ron,
Can you explain your comment more? I'm interested to link the comment to the graph. Is that possible some how to do so?
Regards
Ahmed
stan_koprowski
Hi @acitretin,
cheers,
Stan
