learning_JSL
Level V
Is there a way to group many rows into one row based on matching values of selected fields?
Hi - I have a large dataset with individual contaminant compound results per row.  I.e. Each row has a lat, long, datetime, and a result for one of many compounds.  Instead, I need one row, and only one row, for each instance of lat, long, and datetime....that single row would then have ALL compound results on a single row.   In other words, I need to group by three fields (lat, long, datetime) and present results of all compounds when values of those three fields are the same.  This will allow me to evaluate and explore my data.   (I'm using JMP Pro 17.00.)    Thanks in advance!
WHAT I HAVE:
LAT  LONG DATETIME  COMPOUND   RESULT
lat1  long1   datetime1    sulfate             200
lat1  long1  datetime1     chloride           50
lat1  long1  datetime1      iron                100
lat2  long2  datetime2    sulfate             33
lat2  long2  datetime2     chloride          44
lat2  long2  datetime2     iron                 55
WHAT I NEED:
LAT LONG  DATETIME SULFATE   CHLORIDE   IRON
lat1  long1  datetime1       200              50              100
lat2  long2  datetime2        33               44                55
mmarchandTSI
Level V
Re: Is there a way to group many rows into one row based on matching values of selected fields?
You just need to "Split" the table:
mmarchandTSI
Level V
learning_JSL
Level V
Hi and thanks for your response!  I am exploring this solution now and will let you know if I have any questions.  Much appreciated!
