  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Steffen_Bugge
Access to folder above main script
I am currently using the Get Default Directory function to run a script in a subfolder of my main script, using the following code
relativePath = Get Default Directory();
Include(relativePath || "Folder1/Data import.jsl");
How can I run a script or open a file in a folder above my main script, i.e. in a directory higher than the full directory given by Get Default Directory function?
mmarchandTSI
Level V
Re: Access to folder above main script
This should work for you.
UPone = Left( relativePath, Contains( relativePath, "/", -2 ) );
mmarchandTSI
Level V
Steffen_Bugge
Thanks for the reply @mmarchandTSI !
This takes me one level up, but what if I need two levels up?
Steffen_Bugge
UPtwo = Left( relativePath, Contains( relativePath, "/Folder1/", -2 ) );
Thanks again @mmarchandTSI, I solved it with the above code.
