ravij
Is there a way to force graph builder to use full range axis
When I plot scatter of multiple parameter with different range I am seeing they appear on same level with arrows at the top probably indicating that range is not same for all the plots
Is there a way to force graph builder to give full range axis even if that means few plots completely disappearing as their spread is very small
Re: Is there a way to force graph builder to use full range axis
Yes, change axis merging settings
Parallel Merged might be the one you are looking for. I think there are also some preferences related to this
And you can also find this option from graph builder red triangle when you hold SHIFT while you click on it
