Neo
Neo
Is there a specific Limits Table format for loading limits using Manage Spec Limits ?
I am on JMP16.2 and trying to applying spec limits to test data using a limits table file.
I noticed that the limits table file need to be open for it to show as an option to load. Is this how it is supposed to be?
Also, Parameter Name, LSL, USL columns is what I have got in my limits table, but JMP did not load it when I attempted to load using the "Load from Limits Table" option.  Is there a specific format or the limit table which is allowed?
David_Burnham
Re: Is there a specific Limits Table format for loading limits using Manage Spec Limits ?
There is also an option to save to a table.  So do the save and then look at the layout of the table it creates.
-Dave
There are 2 different table structures that can be used in the limits manager.  A Tall layout that has the limits on different rows, and a wide layout that has the limits in different columns.
Lookup "Limits Data Table" in the JMP Documentation Library for the definition of the 2 table types.
David_Burnham
-Dave
Neo
Neo
Also, want to point out that it seems that the limits table needs to be open for the limits manager to show it as an option for an available limits file.
