Lavik17
Is there a "true" outer-join in JMP?
I am looking for a true outer-join that will return only the mis-matches between the tables based on the match column.
The dialogue allows for including non-matches to the inner match, but there's no option to just search for the non-matches and exclude the inner-match.
Re: Is there a "true" outer-join in JMP?
Is this the situation you are looking for?
You could enable Match Flag, perform full outer join and remove rows which have Match Flags "Both".
I'm not aware of a direct way, but an indirect way is to choose the "Match Flag" option when creating the join, then you can manually/programmatically delete any rows that have the label "Both" in the "Match Flag" column. I've put a script below that does this as an example.
dt1 = open ("$SAMPLE_DATA/Hot Dogs.jmp");
dt2 = open ("$SAMPLE_DATA/Hot Dogs2.jmp");
dt1 << Delete rows (1); //to make an outer join possible
dt2 << delete rows (2); //to make an outer join possible
dtjoined = dt1 << Join(
	With( dt2 ),
	Match Flag( 1 ), //<-use this later
	By Matching Columns( :Product Name = :Product Name ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 1, 1 ),
	Preserve main table order( 1 ),
	Output Table( "joined" )
dtjoined << Select Where (:Match Flag == 3); //JMP uses column values for the text
dtjoined << delete rows ();
Lavik17
Thank you, this would work!
Lavik17
Thank you!
I wish there was an "outer join" option to check when doing a join operation.
