Dear JMP & Community,
I'm running JMP Pro 16.0 on a Windows 10 machine, 64-bit.
I've recently come across a strange potential bug in the Sort function under Tables. When I try to sort the attached data table using the three columns Training R2, Validation R2 and Diff R2, I don't get the output that I would expect.
If I sort it:
Big to small Training R2, then big to small validation R^2, then small to big Diff R2, I get the following (just a screenshot):
![DiedrichSchmidt_3-1630414788751.png DiedrichSchmidt_3-1630414788751.png](https://community.jmp.com/t5/image/serverpage/image-id/35420i461F8D3B8194B974/image-dimensions/874x225?v=v2)
You can clearly see that the validation R2 is actually getting bigger and the R2 Diff is getting smaller. It's as if it only sorted by Training R2 and forgot the rest.
What I would expect is something closer to this (when I sort ONLY small to big R2 Diff):
![DiedrichSchmidt_4-1630414880774.png DiedrichSchmidt_4-1630414880774.png](https://community.jmp.com/t5/image/serverpage/image-id/35421i66A9AB237C67D0A4/image-dimensions/877x228?v=v2)
Even then, it's not quite what I want. What I'm really looking for is having JMP sort out the data so that it first arranges the rows based on the hierarchy that Training R2 is big, followed by Validation R2 big, followed by R2 Diff being small. It used to work this way in previous versions of JMP, but now it seems to be different.
What I'm really hoping to get from the Sort function is for it to arrange the data table such that it finds the entry with the largest Training R2 AND largest Validation R^2 AND smallest R2 Diff. The normal way of doing this by casting the columns as such (below) isn't working like how it did or I think it should.
![DiedrichSchmidt_5-1630415255481.png DiedrichSchmidt_5-1630415255481.png](https://community.jmp.com/t5/image/serverpage/image-id/35423iA5082720D767E54D/image-size/medium?v=v2&px=400)
Our organization hasn't upgraded to 16.1 yet, so maybe this has been fixed. I only have 100 rows in this data table, but sometimes I have several thousand to sort through.
Any feedback much appreciated.
Thanks!,
DS
