Is there a Column Formula to find 2nd highest value?
Hello all -
I am wondering if someone can help with something that has been stumping me in JMP.  I have columns 1-10 that contain a value from the RandomGamma(1) function.  I am trying to come up with a formula to enter for column 11 that would pull out the second highest value of columns 1-10 for any row.  It would be like finding the second highest Maximum for columns 1-10.   Does anyone have any ideas of how to do this?  I am a student who is new(ish) to JMP and would appreciate as simple an answer as possible as I am very much still learning.
Thanks!
Re: Is there a Column Formula to find 2nd highest value?
The Sort Descending() function would return the values in descending order. The following demonstrates the concept.  The subscript of 2 will capture the second highest value. You will need to change the column names to your actual column names:
Sort Descending( Eval List( {:A, :B, :C} ) )[2]
Hope that helps!
Wendy
Hope that helps!
Wendy
Thank you so much!  That is exactly what I was wondering how to do!  :)
