Dorian
Is "Concat Items" only working properly with simple string?
The script below works properly to populate a data table with string items chosen from a list (A to I). However, when I change "A-I" items to mor complex string, for example "Change process based on study results", the script does not poulate the datatable properly (does not transfer at all). Is the "Concat Items" only working properly with simple characters? Or is the problem somewhere else? Thanks for any input!
srimprvTypes = {
    "A",
    "B",
    "C",
    "D",
    "E",
    "F",
    "G",
    "H",
    "I"
New Window("Performance Summary Input: Related Improvements",
    <<Modal,
    <<Size(600, 300),
    Panel Box("Improvement based on results",
        cb48 = Check Box(srimprvTypes),
        Border Box(top(10))
    Border Box(Left(1), Right(5), Top(15), Bottom(5),
        Button Box("OK",
            selectedItems = cb48 << Get Selected;
srimprvText = Concat Items(selectedItems, ", ");
            dt[1, 52] = srimprvText;
Re: Is "Concat Items" only working properly with simple string?
Most likely your problem is somewhere else than with Concat Items
items1 = {"A", "B", "C", "D", "E", "F", "G", "H", "I"};
items2 = {
    "Lorem ipsum dolor sit amet, consectetur adipiscing elit.",
    "Vestibulum hendrerit massa eu blandit accumsan.",
    "Nulla a lectus nec ligula rhoncus ornare."
Show(Concat Items(items1, "@"), Concat Items(items2, "@"));
Craige_Hales
You could use
show(selectedItems);
and
show(srimprvTex);
to help diagnose the problem. The output of show() will be in the log window.
Craige
6 REPLIES 6
items2 = {
Dorian
Thanks -thats right, my problem seems to be in the data transfer.
Craige_Hales
You could use
and
show(srimprvTex);
Craige
Dorian
Thanks -yes it both shows my selection correctly. My problem seems to be somewhere in the transfer to the data table.
I need some help understanding what you mean by "a more complex string".  Could you provide an example?
Items in a JMP list will not be executed prior to being used in the Concat Items.  They must be in the form of
     " values "
items in a list such as
     format(77,9, "Fixed Dec", 6,1)
or
    "A" || "B"
which if executed would produce a simple string, by rule, will not be executed
Dorian
My problem seems to be somewhere in the transfer to the data table, not the concat command. Thanks!
