Neo
Neo
Is "Calculate Quantile Spec Limits Options" available in JMP 16.2?
Is "Calculate Quantile Spec Limits Options" available in JMP 16.2? If yes, could I get an example on how to use/invoke it (as I cannot see /find it)?
https://www.jmp.com/support/help/en/17.1/index.shtml#page/jmp/fit-distributions.shtml
I am especially interested in using "K-Sigma Multiplier" value option.
MRB3855
Re: Is "Calculate Quantile Spec Limits Options" available in JMP 16.2?
Hi @Neo : You will find the details/examples of how to do that here (what you are looking for is down towards the bottom of the page)..
https://community.jmp.com/t5/JMPer-Cable/Modernizing-the-Distribution-platform-Capability-analysis/b...
This was form 2019 and it works the same way in v17. So, it should be good for v16.2.
MRB3855
