lala
Level IX
Is it possible to select cells with the cursor and copy the contents of cells to the paste board?
Hello!
Is JMP possible to select cells with the cursor and copy the contents of cells to the paste board?
  • Select cell[3,1],  then "JANE" copy to paste board.
Re: Is it possible to select cells with the cursor and copy the contents of cells to the paste board?
You could try using Row State Handler. Quick example without proper error handling:
f = Function({a},
	If(N Items(dt << get selected columns) < 1,
		return();
	Main Menu("Edit:Copy", dt << Get Name);
rs = dt << make row state handler(f);
lala
Level IX
This time the web page cannot be translated automatically.The post was over 2 hours.
Does right-clicking on the cell and selecting "Copy" or, alternatively, Ctrl-C do what you want?
lala
Level IX
Thank you very much!
It is my ideal, VBA has cell click event code can be implemented.
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
f = Function({a},
		return();
lala
Level IX
d3 = Current Data Table();
c = (d3 << get selected columns)[1];
r = (d3 << get selected rows)[1];
gm = Column( d3, (d3 << get selected columns)[1] )[(d3 << get selected rows)[1]];
