lala
Level IX
Is it possible to have the "Show Embedded Log" pane open automatically whenever a new Python Editor is created?
I couldn't find this option in the settings.
10 REPLIES 10
Re: Is it possible to have the "Show Embedded Log" pane open automatically whenever a new Python Editor is created?
This will control it for both JSL and Python (to my knowledge)
lala
Level IX
Yes, I think it's only like this when creating a new python editor.
I could only ask the AI to write a JSL myself.It can be achieved.
Thanks Experts!
lala
Level IX
OK、I see
No need for risky GenAI generated powershell. You can use JSL you just have to figure out how to access the correct window (this can depend on how you wish to run the script)
pw = Get Window List()[2];
pw[ScriptBox(1)] << Show Embedded Log(1);
You can also run this automatically using Global Window State Handler
lala
Level IX
Get Preferences();
NO find
Thanks Experts!
Preferences( Script Editor( Show Embedded Log On Script Window Open( 1 ) ) );Wait(0.5);
Try(Main Menu("Python Script"));
Wait(0.5);
Preferences( Script Editor( Show Embedded Log On Script Window Open( 0 ) ) );
What are you trying to do?
lala
Level IX
I want to first use JSL to automatically check this setting of the JMP software, and then create a new python editor.Then uncheck this box so that the "Show Embedded Logs" column does not open when creating a new JSL script.
lala
Level IX
OK
Preference( Script Editor Settings( Show Embedded Log on Script Window Open( 1 ) ) );
Wait( 0.2 );
Try( Main Menu( "Python Script" ) );
Wait( 0.2 );
Preference( Script Editor Settings( Show Embedded Log on Script Window Open( 0 ) ) );
Still no idea what you are trying to do
Main Menu("Python Script");
wl = Get Window List();
wl[N Items(wl)][ScriptBox(1)] << Show Embedded Log(1);
wait(0);
Write();
