Is it possible to execute a script by clicking a curve in the graph via JSL?
lwx228
Level VIII
For example, I made a graph of the script below.
dt = Open( "$SAMPLE_DATA/Students2.JMP" );
dt << Sort( By( 1 ), Order( Ascending ), replacetable( 1 ) );
New Column( "A" );
Column( "A" ) << Formula( If( Row() == 1 | name != Lag( name, 1 ), 1, If( Lag( A, 1 ) < 6, Lag( A, 1 ) + 1 ) ) );
dt << run formulas;
Column( "A" ) << deleteFormula;
dt << Sort( By( "A" ), Order( DEscending ), replacetable( 1 ) );
dt << delete rows( N Rows( Loc( dt[0, "A"] > 0 ) ) + 1 :: N Row( dt ) );
dt << Sort( By( 1, "A" ), Order( Ascending, Ascending ), replacetable( 1 ) );
p1 = Graph Builder(
	Size( 528, 454 ),
	Variables( X( :A ), Y( :height ), Overlay( :name ) ),
	Elements( Points( X, Y, Legend( 8 ) ), Smoother( X, Y, Legend( 9 ) ) )
Click any conditional curve in the graph, and automatically run the specified "D A.jsl"
lwx228
Level VIII
Re: Is it possible to execute a script by clicking a curve in the graph via JSL?
This "D:\A.JSL"、I mainly achieve the following functions:
Click on the selected curve to get the "name".Use this name to get the "age" of the name in another table"Students1.JMP".Create new table "new.jmp"
Draw the diagram as above.
Finally, the two graphs and each data table are used to generate a dashboard.
lwx228
Level VIII
JMP has similar module function, can realize the following process operation:
by clicking the selected curve, get the "name".Use this name to get the age of the name in the other table students1.jmp.A new data table is generated with the selected name alone and the "height" in Table 2 and the "age" in Table 1.
d1 = Open( "$SAMPLE_DATA/Students1.JMP" );
Thanks Experts!
Maybe using Row State Handler on the original data table could work? Or if you can "skip" the clicking part then you could possibly use hover labels.
lwx228
Level VIII
Thank you very much! But I still haven't found a way.
lwx228
Level VIII
lwx228
Level VIII
In my implementation application, the data is not in the same file.So I don't know how to use something like this drill-down function.thanks a lot
ian_jmp
Level X
Perhaps I'm missing some nuance of what's needed. But building on the suggestion from @jthi, you can do this kind of thing (where, once you have the current row selection 'doSomething' can be made to do whatever JSL is capable of):
NamesDefaultToHere(1);
// Original code . . .
New Column( "A" );
dt << run formulas;
gb = dt <<
Graph Builder(
	Size( 528, 454 ),
// New code  . . .
// Row state handler function to do something
doSomething = Function({x}, {Default Local},
						// 'x' is a column vector of row states that have just CHANGED. We just need those that are now selected . . .
						selectedRows = [];
						For( i = 1, i <= NRow(x), i++, If( Selected( Row State( x[i] ) ), selectedRows = VConcat(selectedRows, x[i]) ));
						Print(x);
						Print(selectedRows);
// Assign the handler to the table
rsh = dt << MakeRowStateHandler(doSomething);
