Sully
Is it possible to convert timestamp date to date in Database Query JSL?
I have been searching all over to no avail. I have a new database that I am pulling from and all dates located within are timestamped. I am hoping to get some help on being able to query in this database using just a date and not timestamps using JSL. The column I am using to query is a Numeric Continuous Date column that it's format is m/d/y h:m:s (Width 30 Dec 6) and informat is m/d/y h:m:s
cwillden
Re: Is it possible to convert timestamp date to date in Database Query JSL?
You can try the suggestions here: https://stackoverflow.com/questions/22506930/how-to-query-datetime-field-using-only-date-in-sql-serv...
Or just use use midnight as the time cutoff.  E.g. WHERE TRN_DT >= '11/02/2018 12:00:00.000000 AM' and TRN_DT < '11/03/2018 12:00:00.000000 AM' ); would return any results with any time stamp on 11/2/18.
-- Cameron Willden
cwillden
Are you trying to query dates in a range?  This might be a dumb question, but why not just use midnight for the time portion?
-- Cameron Willden
Sully
I am querying betwen a date range. Perhaps I am overthinking this as I haven't queried using timestamps before (example of what the dates look like in the DB are below).
11/02/2018 10:53:01.465000 AM
11/02/2018 12:40:43.716000 PM
Example of my query is below:
Open Database (
"DSN = PROD; UID= " || ID || " , PWD= " || PASS || "; MODE = SHARE; DBALIAS = PROD;",
"SELECT *
FROM pODSCFView.FRD_TABLE
WHERE TRN_DT >= date and TRN_DT <= date");
DT1 = Current Data Table ();
cwillden
-- Cameron Willden
