Is it possible to add two repression for END of Field? I need to add *F* or ' for field separation.
Re: Is it possible to add two repression for END of Field? I need to add *F* or ' for field separation.
Not sure what can be done in UI/Multiple File Import, but https://www.jmp.com/support/help/en/18.1/#page/jmp/file-functions.shtml?os=win&source=application#ww...
End Of Field("Tab"|"Space"|"Comma"|"Semicolon"|"Other"|"None")
Specifies the quoted character used to delimit the end of a field in the imported text file. To specify multiple characters, separate each character designation by a comma. If you use "Other", designate the delimiter with EOF Other() argument.
Hi Jarmo,
Can you tell me what have I done wrong here?
What I did paste might be related that if you have multiple "pre-determined" separators.
Usually, if JMP's Open() isn't able to handle my text files, I just immediately go with scripting route and write my own custom parser.
Edit: I think the part I should have looked at was combination of End Of Field and
EOF Other(char)
If the imported text file uses an end-of-field character other than the one specified by End of Field(), this argument specifies the character used.
