lala
Level IX
AI:create the L25(5^6) orthogonal array design.
Translate the SAS code in this document to JMP's JSL to implement the construction of orthogonal arrays with an orthogonal Latin square structure. For example, create the L25(5^6) orthogonal array design.
lala
Level IX
Re: AI:create the L25(5^6) orthogonal array design.
lala
Level IX
lala
Level IX
DeepSeek R1 can
What is the purpose of this post? Specific AI model can sometimes do something and sometimes not?
lala
Level IX
Implementation of generating an orthogonal Latin square array with an arbitrary number of factors and levels using JSL. The levels can be non-prime numbers.
