Johnanderson
Inverse Prediction
Dear JMP experts,
I appreciate any clarification in regard to "Inverse Prediction"!
In my databse I have variable represent a biological marker, and I have two level groups (patients A and healthy B). I would like to find a cutoff value for the  marker to say that this value predicts disease at specific probability (data attached).
I did logistic fit, then ROC curve, after then "Inverse Prediction" which gave me the "prediction probability" for every value of the marker (figure attached). My questions are:
1. Are the steps that I followed, correct, to find a cut off value for the marker to predict disease A.
2. What the term "Inverse Prediction" means? more specifically, what the word "inverse" stands for?
Thanks for any clarification
John
John anderson
Re: Inverse Prediction
Start with the ROC Curve. Open the Details report. Use this table to decide the cutoff that you want that satisfies your goals for sensitivity and specificity. Peter's solution is a good one when you know the probability and want to determine the corresponding level of the biomarker.
We usually fit a model to data, generally Y = f(X). We can then use this model to predict Y for a given X. Inverse prediction is used when we want to predict the X value that corresponds to a given Y.
Johnanderson
Dear markbailey, I immensely appreciate your reponse! I would like to know the methods that JMP uses to measure "Inverse prediction" for a certain variable. Is there any reference that may help to clarify how it works?
Sincerely,
John
John anderson
Peter_Bartell
Level VIII
John:
A great place to start learning 'how' JMP does anything is the documentation. Here's a landing page for 'inverse prediction' within the JMP documentation. Inverse prediction as a method is native to several JMP analysis platforms so the exact answer to 'How does JMP do inverse prediction' is dependent upon the analysis platform that was used.
https://www.jmp.com/support/help/14/inverse-prediction.shtml
In addition to the link provided by Peter for the definition, you can find more information by selecting Help > Books > Fitting Linear Models. Go to the Appendix for the statistical details about the inverse prediction method.
Johnanderson
Peter_Bartell and  markbailey, I appreciate your responses. Thank you!
John anderson
