Thanks for your comments. My study has both factorial and mixture components.
There are three categorical factors:
- Agg Type-Class A (Levels: A1, A2, A3)
- Agg Type-Class B (Levels: B1, B2, B3)
- Gradation Type (Levels: Type C, Type D)
Then there are two mixtures, where each is a two-component mixture.
- AggBlend, Coarse (A_Coarse + B_Course = 0.5)
- AggBlend, Fine (A_Fine + B_Fine = 0.5)
Can you clarify what you mean by "you did ratios rather than the independent amounts of coarse and fine?" I think I did not do ratios.
- Coarse (A=0.2, B=0.3) + Fine (A=0, B=0.5) = 1.0
Because it's just two components, are you saying I could have changed the 4 mixture variables to 2 continuous ratio variables? (Ratio of A/B_Coarse, and Ratio of A/B_Fine). When I've done this in the past, I ran into problems with the analysis of AggType * AggRatio interactions. (I can expound on those problems if needed).
Here's what the DOE dialogue looked like.
I don't know how I got here with the model, but I think there are problems. (1) I am missing the AggType main effects. (2) Some interaction terms don't make logical sense.
- The first interaction, AggType, Class A * AggBlend, Coarse_Class A, would show how the Class A Agg type varies by it's amount in the mixture. And for test runs where Class A is not in the mixture (Blend Class A=0), it's effect wouldn't be considered. But the next interaction, AggType, Class A * AggBlend, Coarse_Class B, seems to be looking at the exact same thing, but the inverse. The mixture constraints mean that B Blend = 0.5 - A Blend.
- The interaction, AggBlend, Coarse_Class A * AggBlend, Coarse_Class B, doesn't seem helpful at all. This is just the interaction of A Blend and 0.5-A Blend.
If I build the model intuitively, I end up with the following. Does this seem valid?
