@FN
If you do not want to create a custom application or script, you might be able to use Nonlinear platform. This platform was designed for solving for parameters, but the resulting analysis might be a good fit for what you are looking for.
1. Create a column formula and assign the variable n as a parameter.
![scott_allen_0-1713198945420.png scott_allen_0-1713198945420.png](https://community.jmp.com/t5/image/serverpage/image-id/63346i9CBD697063D3FE31/image-size/medium?v=v2&px=400)
2. Launch the platform (Analyze > Specialized Modeling > Nonlinear). Assign column Y as the Response and column Calc Y (the one with the column formula) as the X, Predictor Formula.
3. Adjust the n parameter with the slider. If there are multiple parameters, there will be multiple sliders. The points represent the curve for the value assigned to n in the column formula and the curve will show the effect of changing n.
![parameterSlider.gif parameterSlider.gif](https://community.jmp.com/t5/image/serverpage/image-id/63347iAE625551A616AE34/image-size/medium?v=v2&px=400)
-Scott
