Interactive plots
This stopped working after updating to the new version of JMP. I used to be able to make interactive html bar graphs. If I keep the syntax the same on the new JMP version, the plot remains interactive but the labeled values are rounded to the nearest whole number instead of including the decimals. When I add a line to display the decimal places, the graph no longer is interactive in html.
Bar(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Y( 4 ),
Y( 5 ),
Y( 6 ),
Y( 7 ),
Y( 8 ),
Y( 9 ),
Y( 10 ),
Y( 11 ),
Legend( 25 ),
Bar Style( "Stacked" ),
Label( "Label by Value" ),
Label Format( "Best", 4 ) --> this is the line that when included stops the html graph from being interactive.
Does anyone know a fix for this?
Re: Interactive plots
One workaround you might try is setting the desired format using the "Axis Settings" dialog (in the menu when you right-click on the Y axis in Graph Builder), instead of changing Label Format. The bar label values should get the same format as the axis values.
In what older version did the interactivity work?
What interactivity do you expect to see?
I went from using JMP 16 to JMP 17. The graph being produced is a weekly Yield plot for the last quarter. In JMP 16 when I created the interactive HTML plot, you could hover over the bars and it would tell you the rows of the failures. There is also a yield line that when you hover over it with your mouse it shows you the value of the line. Now with JMP 17 when I hover over the plot I got a message at the top of the screen that says "this plot is not interactive".
So the main issue is that when you specify the format to use for the Labeling on the bar chart, that you loose the hovering interactivity.    But, if you do not set the format label, the interaction you want is there.
I do not know a work around.
I suggest you contact JMP Support directly.
This worked! though I am not sure how or why. Thanks!
