Interactive binning > how to jitter points ?
In the Interactive binning interface, in the bottom section (plotting points distribution),
how can I specify that jitter type ?
I know it's feasible, because it used to be jitter "packed" (i.e mandolin graph), but the default jitter looks to be a "uniform" jitter which is less useful for interactive binning.
Re: Interactive binning > how to jitter points ?
You mean this interface (I'm using JMP17)?
Right click on the area of graph where markers are, select customize, marker and change as needed
