Feli
Installing python packages in JMP 19
I was following the instructions in the online help to install python packages (pandas, numpy, ...) that I need for my scripts, but I am having trouble.
When I run
Python Install Packages( "pandas" );
(I needed to change to "" for it to work), I'm getting the error:
import jmputils
jmputils.jpip('install', 'pandas')
ERROR: Can not perform a '--user' install. User site-packages are disabled for this Python.
My guess is that the issue is that I would need admin rights to write to the windows folder where JMP sits, but I can't find anything in the help on how to solve this issue.
Feli
Re: Installing python packages in JMP 19
The final solution in the end was that somewhere in my System environment variables, the PYTHONNOUSERSITE was set to 1 (probably from an earlier python installation). Setting this to 0 fixed the issue
17 REPLIES 17
Level XIII
JMP/Python can be found in
C:\Users\__username___\AppData\Roaming\JMP\JMP\Python\Python313
Have you tried installing from Python Script Editor?
import jmp
from jmputils import jpip
# update to latest version of pip and setuptools then install numpy & pandas
Feli
That was my first try, but gives the same error:
Some sort of issue related to this seems to be known, but not really sure if the "solution" is helpful (close and re-open JMP),  Scripting Guide > Python > Install a Python Package > Avoiding Errors with Previously Installed Pac... .
Last option that comes to my mind is to use command line with Python Create JPIP CMD(); or jmputils.create_jpip, Scripting Guide > Python > JSL-to-Python Interfaces > Install Python Packages using JSL .
@Paul_Nelson
Feli
Your first suggestions seems to match what might be happening to me: pandas and numpy have been installed before on my JMP 18 installation on the same system. Maybe that is what is clashing now.
I think I will have to open a support case with JMP to get to the botton of this.
Thanks for all your help!
There should be no conflict between JMP18's Python and JMP 19 Python site-packages.  Python itself creates a Python versioned subdirectory.  C:\Users\<User>\AppData\Roaming\JMP\JMP\Python\Python313 for JMP 19,  ...\Python311 for JMP 18.
Feli
That could be a hint. I don't have such folders in my User folder, but it seems that such a Python folder is rather in my C:\Programs\JMP\... .  Since I have no write rights into this folder, that might cause this error. What I am not sure about is why a) this worked for JMP 18 before (where I could initialize pandas and co) and the folders are the same (no User folder, Python sitting in the programs folder) and b) why it was installed there.
Vball247
Hi Feli. If you do not see the AppData folder, make sure it is not "hidden". For Windows, in File Explorer, go to the View menu, then Show. There is an option called "Hidden items", it is not checked by default. Check this and then you should see the AppData folder and subfolders. Common issue for our JMP users.
https://support.microsoft.com/en-us/windows/file-explorer-in-windows-ef370130-1cca-9dc5-e0df-2f7416f....
Open File Explorer  from the taskbar. Select View > Show, then select Hidden items to view hidden files and folders.
This python script updates jpip and installs pandas.
import jmputils jmputils.jpip('install --upgrade', 'pip setuptools') jmputils.jpip('install', 'pandas')
