Inserting page breaks in journals
Hi Guys,
I am trying to save a journal report with > 1000 parameters into a rtf file. However, when I see the plots in the word file, the plots for the parameters are getting cut. I would like to add page breaks before every parameter so that all the plots for each parameter are on one page. I know if I right click on the blue triangle, I can insert a Break but I don't want to do this for > 1000 parameters. Is there an easier way to do this?
Thanks.
9 REPLIES 9
Re: Inserting page breaks in journals
Anybody has any ideas on this?
Appreciate any help with this.
Thanks.
gda
gda
Take a look at the "Manipulating Displays" section of the scripting guide.
There is a "Page Break" message you can send that will do what you're requesting. Without knowing the tree structure of your report it's hard to get too specific.
Below is an example of making a page break in a specific section.
tova
I don't see the example.
Here is the example taken from the Scripting Index
     Help==>Scripting Index
//This message applies to all display box objects
New Window( "Example",
	ob = Outline Box( "Outline Box",
		V List Box(
			ob2 = Outline Box( "Outline Box 2",
				H List Box(
					Text Edit Box( "Top Left" ),
					Text Edit Box( "Top Right" )
			ob3 = Outline Box( "Outline Box",
				H List Box(
					Text Edit Box( "Bottom Left" ),
					Text Edit Box( "Bottom Right" )
ob3 << Page Break;
tova
thanks
How can I undo the page break in journal?
I don't see any clear way to do this.  Hopefully some other Community Member may have a solution.
If we are talking about PageBreakBoxes then...use XPath to get references to all of them and then send << Delete box() message to those references
nw = New Window("Example",
	ob = Outline Box("Outline Box",
		V List Box(
			ob2 = Outline Box("Outline Box 2",
				H List Box(Text Edit Box("Top Left"), Text Edit Box("Top Right"))
			ob3 = Outline Box("Outline Box",
				H List Box(Text Edit Box("Bottom Left"), Text Edit Box("Bottom Right"))
ob3 << Page Break;
nw << Journal;
(Current Journal() << XPath("//PageBreakBox")) << Delete Box;
It also might be enough to just send << Visibility("Collapse") instead of deleting them
Nice solution!
