WebDesignesCrow
Insert Today date in Graph Title automatically using script
I want to insert today date in Graph title.
The script run daily, so I want the title date change with run date.
I add script below but it didn't work.
Any idea how to insert today date in the graph title?
		Dispatch(
			"Distributions",
			OutlineBox,
			{Set Title( "Distributions of last 30 days as of" & Today() )}
The log:
Re: Insert Today date in Graph Title automatically using script
There are a couple of issues.
  1. The & is not the concatenation syntax.  two vertical bars is what is used    ||
  2. The Today() function does not return a string, it return a numeric value, which is the number of seconds since Jan 1, 1904.  You need to use a Format() function to convert the Today() function.    Format(today(),"m/d/y", 10 )
WebDesignesCrow
Splendid !
Thanks, it solved the problem.
Dispatch(
			"Distributions",
			OutlineBox,
			{Set Title( "Distributions for last 30 days as of " || format(today(),"d/m/y",10); )}
WebDesignesCrow
Splendid !
Dispatch(
			"Distributions",
			OutlineBox,
