sid265
Individual sets of data points Smoothing/Spline Fitting in Graph builder
I'd like to know if there's anyway of adjusting the lambda in smoother for  individual sets of datapoints.  For eg: can only the fitting of the cyanish curve be modified without changing the fitting of the other curves? Thank you!
Re: Individual sets of data points Smoothing/Spline Fitting in Graph builder
You can use Fit Y by X and then set the Group By, and then do a Flexable==>Fit Spline.  Each group will have it's own Lambda slider
dt << Bivariate(
	Y( :height ),
	X( :weight ),
	Fit Where( :sex == "F", Fit Spline( 1000, {Line Color( {212, 73, 88} )} ) ),
	Fit Where( :sex == "M", Fit Spline( 1000, {Line Color( {66, 112, 221} )} ) )
dt << Bivariate(
	Y( :height ),
	X( :weight ),
