Increment a value for Run Number
I am trying to develop a formula that increments up the Run #. It should count up for each time a Shop Order has a new Process ID and reset back to 1 when a new Shop Order has not been run before. As shown below the Shop Order 532 has 3 different Process IDs, but they are not in order so it still increments up to 3 on the final one even though it isn’t in order. I created a column manually showing what I would want as an ideal outcome for the formula column. How would I write a formula to deal with this issue?
Re: Increment a value for Run Number
OK....my oversight again....I think the approach below solves the issue
// Create a column that when the data table is sorted, it can be returned to the original
dt << New Column( "theRow", formula( Row() ) );
// Remove the formula to turn the values into static values
:theRow << delete formula;
// Sort the data into an order where all Process ID for a given Shop Order are together
dt << sort( by( :Shop Order, :Process ID, :theRow ), replace table( 1 ) );
// Create the Run # column
dt << New Column( "Run #",
	formula(
		If( Row() == 1 | :Shop Order != Lag( :Shop Order ),
			count = 1,
			If( :Process ID != Lag( :Process ID ),
				count
		count;
:"Run #"n << delete formula;
// Sort back into the original row order
dt << sort( by( :theRow ), replace table( 1 ) );
// Delete the no longer needed theRow column
dt << delete columns( :theRow );
Here is a formula you can use.  Create the new column Run #.  I suggest you make the modeling type "Ordinal".  Open the Formula Editor for the new column, and paste in the following.
If( Row() == 1,
	:Process ID << set property( "Value Order", {Common Order( 0 ), Row Order Levels( 1 )} );
	Summarize( byGroup = by( :Process ID ) );
	:Process ID << delete property("Value Order");
Below is a script that will do the column creation and apply the formula for you
	ordinal,
	formula(
		If( Row() == 1,
		Contains( byGroup, :Process ID );
Thank you for this. It doesn't quite do what I am looking for. See the mismatch between the "Ideal Outcome Column for Run #" and the "Run #". The way the formula is currently working is just incrementing up no matter if a new SO is started.
Sorry, I missed the link with Shop Order.  That changes everything and makes the formula much simpler
	count = 1,
		count
count;
That was closer, but it restarted the count for Shop Order # 532 at 1 the second time that it was listed since there was another Shop Order between runs 2 and 3. The image below shows the highlighted cells where it deviated from the Ideal Outcome.
	formula(
			count = 1,
				count
		count;
