screech
Increment a counter from 1 to n for every unique set of identical rows
Hi everyone,
I figure what I want to do is really easy, I just haven't come up with a good way to do it. I have a large table with a substantial number of identical rows which I want to rename uniquely but in a reproducible way. Currently, I have a script that takes the following column:
A number 1
B number 1
A number 2
A number 3
A number 3
A number 3
B number 3
B number 3
B number 3
Into into a new names column, using the row index identifier:
A number 1
B number 1
A number 2
A number 3
A number 3 5
A number 3 6
B number 3
B number 3 8
B number 3 9
That code is
Names Default To Here( 0 );
RawFile << New Column( "itemname2", Character, Nominal );
Current Data Table( RawFile );
For( i = 2, i <= N Rows( RawFile ), i++,
	If( :itemname[i] == :itemname[i - 1],
		:itemname2[i] = :itemname[i] || " " || Char( i ),
		:itemname2[i] = :itemname[i];
This works well enough, but the issue here is I want the output to instead increment from 1 each time it needs to be used, to give something like
A number 1
B number 1
A number 2
A number 3
A number 3 1
A number 3 2
B number 3
B number 3 1
B number 3 2
I know this should be simple, but I'm not sure how to structure/limit the loop....any help would be appreciated. Thanks!
screech
Re: Increment a counter from 1 to n for every unique set of identical rows
Nevermind.....realized I just needed the initialization of the second counter outside the loop. Cheers!
k=1; For( i = 2, i <= N Rows( RawFile ), i++, If( :itemname[i] == :itemname[i - 1], :itemname2[i] = :itemname[i] || " " || Char( k );
k++, :itemname2[i] = :itemname[i];
k=1 ); );
screech
k=1 ); );
