Increasing trend using Jmp Code
I have a cycle (Cycle 2) that last for certain rows and then increases its step. For each cycle, I would like to make another column(Column 7) and assign an increasing trend of same numbers but I could not figure out the code for this.
Re: Increasing trend using Jmp Code
Try Col Rank formula
Col Rank(:"Cycle 2"n, :"Cycle 2"n)
Georg
Perhaps it is ->> Tables --> Split that can help you?
Georg
@George
Thanks
I don't have the trend column as you show. I want to create "trend" and assign an increasing order of numbers to it
I only have this
