prmiszkiewicz
Include current date in name of saved file?
I have a script which saves results to PDF file with a name specified in the script by using save pdf command. Currently I have to manually adjusst the file name so that the older one doesn't get overwritten as the script is run every few days. Is there any way to include the current date in the file name in an automatic way?
Byron_JMP
Re: Include current date in name of saved file?
Here's an example where a table is opened and saved with the current date. The last line saves the table with today's date embedded in it.
Also, Its important to pick a date format that doesn't have a "/" or a ":" in it.
//Earth Quates, last 7 days
cd=get default directory();
data=expr(quake = Open(
  //"/0000000027230BB0/eqs7day-M1.txt",
  "http://earthquake.usgs.gov/earthquakes/catalogs/eqs7day-M1.txt",
  columns(
  Src = Character,
  Eqid = Character,
  Version = Character,
  Datetime = Character,
  Lat = Numeric,
  Lon = Numeric,
  Magnitude = Numeric,
  Depth = Numeric,
  NST = Numeric,
  Region = Character
  Import Settings(
  End Of Line( CRLF, CR, LF ),
  End Of Field( Comma ),
  Strip Quotes( 1 ),
  Use Apostrophe as Quotation Mark( 0 ),
  Scan Whole File( 1 ),
  Treat empty columns as numeric( 0 ),
  Labels( 1 ),
  Column Names Start( 1 ),
  Data Starts( 3 ),
  Lines To Read( All ),
  Year Rule( "20xx" )
quake<< set name("Earthquakes "||short date(today()));
quake<< new column("DateTime2", <<format("m/d/y h:m:s"),
  formula(
  l = Words( :Datetime, " ," );
  d = l[3] || Substr( l[2], 1, 3 ) || l[4] || " " || l[5];
  Informat( d, "ddMonyyyy h:m:s" );
data;
quake << Save as( cd||"Earthquakes "||Format Date( Today(), "ddmonyyyy" )||".jmp" );
Byron_JMP
  columns(
  Src = Character,
  Eqid = Character,
  Lat = Numeric,
  Lon = Numeric,
  Depth = Numeric,
  NST = Numeric,
  Region = Character
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 1 ),
  Data Starts( 3 ),
  Year Rule( "20xx" )
  formula(
data;
prmiszkiewicz
Thank you very much, I'm new to JMP, so didn't think it will work almiost in same way like in C++
