shankyjain
In JSL having trouble adding a new column to a newly transposed datatable
Here is the complete log
Log output:
Column not found in access or evaluation of 'Bad Argument'
Send Expects Scriptable Object in access or evaluation of 'Send' , dt_3 << New Column( "Dev", Character, Nominal, "Source" )
In the following script, error marked by /*###*/
dt_1 = Current Data Table();
cc = dt_1 << Get Column Names;
cc[3] << Set Selected( 1 );
For( i = 36, i <= 58, i++,
  cc << Set Selected( 1 )
dt_2 = dt_1 << Subset( Selected, Output Table Name( "I_tmp" ) );
cc = dt_2 << Get Column Names;
ncols = N Items( cc );
For( i = 2, i <= ncols, i++,
dt_3 = dt_2 << Transpose(
  columns( Selected ),
  By( :Column 1 ),
  Output Table Name( "I" )
dt_3 << /*###*/New Column( "Dev", Character, Nominal, "Source" ) /*###*/;
ms
Super User (Alumni) ms
Re: In JSL having trouble adding a new column to a newly transposed datatable
:Column 1 refers to Column("Column 1") whereas Column(1) refers to the first column. Column(dt_3, 1) refers to the first column in data table dt_3.
shankyjain
Found Partial Answer: Had to change columns(Selected) to (Selected) in
By( :Column 1 ),
But, my way referring to first column as :Column 1 in By() is not working. Is there as way to refer to columns by say first, second rather than their actual names?
ms
shankyjain
Column(1) refers to first column in table you mean, then i can give Transpose(columns(1,5,8), By(column(4))..... right?
ms
Yes, that should work.
(Sorry, I've edited my confusing typos in previous post)
