shankyjain
In JSL how to save New Window HList Box multiple Bivariate plots as a script in datatable
In manual plotting, I usually plot a multiple bi-variate plot and use the option "save script for all objects" and copy the contents of generated script as a new script within the datatable and save the datatable. This way, next time i can run the script to generate the plot.
Now, in JSL i have copied the script generated by "save script for all objects" but don't know how to pass commands to save this as a script in the datatable on which the main JSl script is operating!
Finally , i just want the plot to be saved as a script within the datatable by using JSL as i'm already generating the datatble in JSL
code generated by "save script for all objects"
New Window( "Plot - Fit Y by X of Id_%deg, IDF(uA) by time 2",
  H List Box(
  Bivariate(
  Y( :Id_%deg ),
  X( :time ),
  Dispatch(
  "1",
  ScaleBox,
  {Scale( "Log" ), Format( "Scientific", 12 ),
  Min( 0.73058544209732 ), Max( 20000 ), Inc( 1 ),
  Minor Ticks( 8 ), Show Major Grid( 1 ), Show Minor Grid( 1 ),
  Rotated Labels( "Horizontal" )}
  Dispatch(
  "2",
  ScaleBox,
  {Scale( "Log" ), Format( "Best", 12 ), Min( 0.0142496799685873 ),
  Max( 46.3114598979087 ), Inc( 1 ), Minor Ticks( 8 ),
  Dispatch( {}, "Bivar Plot", FrameBox, {Frame Size( 348, 274 )} )
  Bivariate(
  Y( :Name( "IDF(uA)" ) ),
  X( :time ),
  Dispatch(
  "1",
  ScaleBox,
  Min( 6.53505316748169 ), Max( 20000 ), Inc( 1 ),
  Dispatch(
  "Bivar Plot",
  FrameBox,
  {Frame Size( 348, 274 ),
  Row Legend(
  Measurement,
  Color( 1 ),
  Color Theme( "JMP Default" ),
  Marker( 0 ),
  Marker Theme( "" ),
  Continuous Scale( 0 ),
  Reverse Scale( 0 ),
  Excluded Rows( 0 )
  ), Row Legend(
  Site,
  Color( 0 ),
  Color Theme( "" ),
  Marker( 1 ),
  Marker Theme( "Standard" ),
  Reverse Scale( 0 ),
  Excluded Rows( 0 )
Finally , i just want the plot to be saved as a script within the datatable by using JSL.
ms
Super User (Alumni) ms
Re: In JSL how to save New Window HList Box multiple Bivariate plots as a script in datatable
You can add a table script like this:
dt << New Table Script( "My plot", jsl_expression... );
ms
shankyjain
Thanks and that was quick reply!!
