Hester
If a column contains "%"--> how can I use this type for a formula? i.e. if states "%" do formula, otherwise use a number from another column?
I'm struggling. I have a column which contains either %, /nl or 10^9 as a outcome. the linked numbers in another column have to be converted depending on these expressions. How should I use the column properties and which comparison or expression in the formula should I use? Most use a numerical part for this, but I need now the characters.
if --> % than calculate number *100, if not do xxx
Craige_Hales
Re: If a column contains "%"--> how can I use this type for a formula? i.e. if states "%" do formula, otherwise use a number from another column?
A picture would help. Is the column a character column, showing the % or / or ^ ? Or is it a numeric column with just a number?
If it is a character column, the contains() function might do what you need.
contains("37%", "%")
3 // position of the %
contains("37%", "/")
0 // / not found (position 0 not a valid position)
Craige
